Scotty
- Scott
- Oct 7, 2020
- Los Angeles
- Taycan4s
- #1
The NHTSA issued the below campaign for Taycan's 2020-2022. My dealer performed the campaign and nothing but problems now with the climate control system. First the A/C stops working after 5 mins. Took car back for reprogramming. The A/C now works but there is no warm heat anymore for defroster or heating the inside of the car. Took car back again today to see if they can figure out. Seems Porsche is reporting a number of issues with owners regarding this campaign. Anyone else having same issues as I am?
Models
Model Years
VIN list
Number of Affected VINs
Issue Description
WMP5
Taycan (Y1A/Y1B)
2020-2022
Attached below
3,774
Due to a manufacturing error at the supplier, pressure sensors for the refrigerant circuit were installed on the affected vehicles that do not meet the required speci- fications.
The failure of one or more pressure sensors in the ref- rigerant circuit can therefore not be ruled out over the lifetime of the vehicle. As a result, there is a possibili- ty that the air conditioning and battery cooling system will not function as normal. This can lead to an incre- ased temperature of the high-voltage battery and, as a result, to reduced charging performance during fast charging, and possibly reduced driving performance.
To prevent this from happening, the pressure sensors must be checked and replaced if necessary.
As of the time of this posting, the repair is imme- diately available.
Parts can be ordered via PPL Order with no PRMS Ticket needed.
Models
Model Years
VIN list
Issue Description
WMP5
Taycan (Y1A/Y1B)
2020-2022
Attached below
3,774
