Using Panamera brakes/wheels on Taycan
Maimai
PNW
Hi all,
After tracking my car over the last several months, I am looking to replace the stock brake pads and tires with Panamera parts due to their availability. Upon reading the forum, several questions came up:
1. My car comes with the 10 piston front brake caliper. Which Panamera brake pad profile will fit? Any recommended aftermarket brands?
2. I plan to use the Panamera OEM 20in BBS wheels as the front wheels are wider than the Taycan version, which will provide me with additional front tire size options. That being said, the wheel offset seems to be different, do I need to use spacers/extended bolts to make them fit on Taycan?
Taycan 20in specs
9Jx20 ET54
11Jx20 ET60
Panamera 20in specs
9.5Jx20 ET65
11Jx20 ET68
SilverSpecter
Philippines
Taycan Turbo S
  1. For your 10 piston front brake caliper, look for Panamera brake pads compatible with this setup. Stick to OEM options for the best fit, or consider aftermarket brands like Brembo, EBC, or Hawk Performance.
  2. Since the offsets differ between Taycan and Panamera wheels, you may need spacers or extended bolts for proper fitment. Consult a mechanic or specialty shop for a precise solution tailored to your setup.
Donar
Netherlands
Taycan ST ‘22 - Polestar 2 Performance '20
And check if installing non OEM Taycan wheels will void warranty. I think it does for my CPO warranty (like installing any after market item).
mystermykee
Bay Area
9j1, 9y0 hybrid, 992.1
Possibly related question. Will Panemera PCCBs fit the Taycan?
