Change configuration after freeze date?
yoursuf
Chicago
TAYCAN
Has anyone tried or had luck adding an option to configuration after freeze date? I placed my base model order… it has everything I wanted.. except one, PTV+. Now I am going crazy about not adding it, the car is past the freeze date and is now under planned for production phase. Is it possible to get PTV+ added now?
VA_CT
Bay Area, CA
2019 Macan, 2022 4CT
You could, talk to your SA. I would caution against doing this to avoid any delay with your delivery
Midlifecrisis
Worcestershire
Likely to push you back down the queue if you change now. Are you going to track the car? If not, do you really need it for normal driving?
yoursuf
yoursuf
Chicago
TAYCAN
Thanks all for inputs, I called the dealer and seems I can NO longer make changes. I guess the only I reason I wanted to have PTV+ is, for better control when driving in rain or snowy conditions.. I personally avoid driving during snow... but can't avoid driving in rain lol. With that said, this will be my first RWD car and not exactly sure how PTV+ will help the RWD in bad weather conditions.... This will be my daily commute car to work.. mix of highway/local... not planning to take it track, moreover never been there :CWL:.
So hope excluding PTV+ for daily normal drive was not a bad a decision :)
Below is my build.... ignore the ugly wheels. I have ordered aftermarket Vossen HF-4T 21 wheels and will be installed same day I pick up the car and the brake calipers will be coated red.
http://www.porsche-code.com/PNVNZ8I5
