Charging issues
Bob
Columbia, SC
Last year, I had to lower the amperage on the charger to 30A because it was overheating and failing. That has worked well for a year, but now, I had another failure (flashing blue light) and I had to lower the amperage to 20A. Has anyone had any similar problems or heard about failures? Bob Borucki [email protected]
xirtam2381
SoCal
Taycan 4s
I think flashing blue light means you have a charging profile set to only charge at a scheduled time?
Fish Fingers
Sold
As above.
I have my car set with a Timer to make use of the cheap rate electricity overnight.
When I plug it in (as long as its above my minimum set 55%) I get the pulsing blue light.
Basically, it's on pause waiting to start the charge at midnight - when it will turn green.
In the morning its done its thing and is charged.
As has been noted flashing blue as documented in the Porsche Good To Know App and clearly indicated on the charge port door simply means your charging process has paused waiting on the next programmed timer event ie when a daily timer has been set (AC charging).
When red then you have a problem.
Bob
Columbia, SC
Thanks for the ideas all.... I am not sure though, since it starts charging for a half hour or so with green, then stops and flashes blue. I have never set a scheduled time for charging on the unit. More to follow as I investigate.
There is nothing to set on the unit (EVSE) if PMC+ or PMCC.
Check what timers and profiles you have enabled either via the PCM or app as it sounds like there are competing ones.
