Dipped beam converted!
Gwaihir
Ken
Taycan GTS ST
The “Dipped beam converted” message appears on my car when first started and I’m not sure why? Looking in the manual this conversion is to cast the dipped beam away from oncoming traffic and is directed by navigation data knowing your location and if it’s left, or right had driving. As I’ve a UK car I would have expected it to default to the UK, rather than the display showing a conversion is needed. I have manually changed the setting, but it reverts back agin, presumably from navigation knowledge. has anybody else in the UK got this problem? It’s as if the car has not been fully setup for UK use. . .
Persuader
2024 Taycan Turbo S Cross Turismo, 2024 Range Rover L461, 2020 Aston Martin DB11
Mine does this too.
Gogs
Gordon
Aberdeen, Scotland, UK
That's a setting on the car, so when your driving wrong side of the road you can convert the bream to avoid dazzling drivers.
Persuader
Yes. But it still dose not make sense that it displays "Dipped Beam Converted" every time we start the car.
Gogs
Gordon
Stupid question, but I assume you have the option de-selected?
jetbox
Scotland
Yes
Mine does this too on every startup. I’ve not thought much of it until now...
the selection for changing the beam is NOT selected
Persuader
On mine I get the message on startup irrespective of whether it is selected or not.
Gwaihir
Gwaihir
Ken
Taycan GTS ST
I think the software default is Germany, so when in the UK (it knows through sat nav) it changes the dipped. Another implementation that needs fixing. . .
Gogs
Gordon
I don’t think I get any messages. What am I looking for?
Peterw
Uk
Taycan turbo -soon
I don’t think I get any messages. What egault am I looking for?
I can also confirm no message - so there must be a setting to create a Rhd or LHd default that “ sticks” when car turned off
Squarecircle
4s +
Mine does say it on start up each time. Just pops up on the right hand side of the drivers screen.
Gogs
Gordon
No I don't get the message. I'll have a look for the settings as I do remember a setting when I went and setup the car at day 1.
Gwaihir
Gwaihir
Ken
Taycan GTS ST
The message only appear if you press the start button on entering the car. If you let it self start - ie, unlock, jump in, press brake pedal and close the door it doesn’t appear. Maybe that’s how you start your car?
The message appears in the far right display and goes away when you select motion.
