Editing Destination Names
PAB
PAB
UAE, CH, RSA
Taycan Turbo S, Macan Turbo, Macan EV
In South Africa, the Taycan does not yet have an embedded SIM and Porsche Connect is not available. My dealer and I are unable to figure out how to edit the names of destinations. For example, instead of saving a destination by its street name & number, once the street & number are entered and saved as a destination, how do we edit the name to be, for example, the name of the person living there. Anybody figured this out? Thank you!
Can't you simply search for the destination on the PCM and save with your own chosen name for it or alternatively, use the contacts in your phone (with an address) and sync to the PCM with in car hotspot and pick the one you want - it will then add as per your contacts?
Also, have you tried holding your finger on the entry to see if a sub-menu pops-up / or swip the entry left or right, also try adding to your favourites as this might let you rename?
Porsche Taycan Editing Destination Names 1630435431807
Reactions: PAB
PAB
PAB
PAB
UAE, CH, RSA
Thank you Winge. The answer is No to the first suggestion, and will try your second two suggestions tomorrow. Thank you!
