Ev charger
Smiy
Vancouver
Taycan 4s
I just had my ev installed at home. The installer said he has installed 40 amp charger. I did my first charge and it was charging at 8.5 kWh and 0.6 km a minute. When I did some research it shows that a 40 amp should have 9.6kw with 240 volts.
When I asked my ev installer he said the 40 amp output is regulated at 80 percent hence the lower kw. Is that right?
X88
Zain
2022 Taycan GTS
I'm not sure about Canadian regulations, but in the U.S. the requirement is that the breaker in the electrical panel should be sized such that it can deliver 100% of the rated current for peak loads and 80% of the rated current for sustained loads. EV charging represents sustained loads, so to get 40A charging into your EV the breaker should be rated at 50A.
goofysurfer
Los Angeles
Cayman 981 2.7, 4CT
He installed a 50 amp circuit breaker. 50 * 0.8 = 40 amps available. And 240V * 40A / 1000 = 9.6kW. But there are other factors like temperature and battery state, which is regulated by the car's charging ability. So at 8.5 KWh, it seems like it's working fine.
Jeremy
St. Louis, MO
2022 Macan S; 2021 Taycan 4S
8.5 is approximately correct after losses. The 9.6 is at the EVSE. The battery will see less.
The 80% is 40A relative to the 50A branch circuit (breaker, wire, and receptacle).
zzy45
Eric
Canada
Taycan GTS
Just had my NEMA1450 installed last week, similarly 50A circuit breaker. Really look forward to bring the car home and see how it goes. The gas price @Toronto today just hit another record high,
Can’t wait…
Rob28
Robert
Canada
'22 Taycan GTS, '22 Lexus NX350 (Wife's)
Same boat as you guys! Just have my NEMA 14-50 installed this week - car is expected in the next couple weeks (i think will be at the dealer this week). Ahh can't wait!
Anyone know of Porsche meet ups in the GTA area?
