TSB: Customer inability to charge Taycan using provided charger with 120V. July 8, 2022
"The Taycan requires a minimum 800W of charging power. The standard Mobile Charger Plus has a default current setting of 50%, and the optional Mobile Charger Connect has a variable current setting. Depending upon the input voltage to the charging hardware, the current setting can result in insufficient charging power for the Taycan.
For example, charging with the 120V supply and 6A current setting provides a maximum 660W of charging power - insufficient to charge the vehicle.
The customer must adjust the current setting."
https://static.nhtsa.gov/odi/tsbs/2022/MC-10217192-0001.pdf
