TIM
- Philippe
- Mar 10, 2019
- Switzerland
- Yes!
- #1
these instruction are either for:
1. Login to Porsche Connect and click "service overview"
2. Click "navigation plus"
3. Click "new"
4.1 Type in your adress until you have a "more-or-less" fittable google adress
4.2 Select the google adress
5. Type in your destination name (in this case Porsche Lausanne).
5.1 you can change the destination name if you slightly move the destination on the map "up and down - back to it's initial position" you 'll see that a "cross" will come that will let you edit the destination name
6. You can use the map to define exactly where you want to "place" your location
RESULTS
7.1 on the map from the Connect Portal
7.2 on the favorites from the connect portal
7.3 the detailled adress
you'll notice that the destination name has change (I guess that what Goggle has in database for this adress) BUT not the favorite name in the Connect Portal nor in the Favorites from the car
7.4 on the PCM from my Taycan (it need a few minutes to receive it from the Porsche Connect)
- setting up a new favorite with custom name [1. - 7.4]
- changing the name of the favorite [5.1]
3. Click "new"
RESULTS
