Panamera wheels fit a Taycan?
jetbox
Scotland
Yes
Will Panamera wheel fit a Taycan? I will be looking for a set of winter wheels and wonder if they will fit?
Chowster
Vancouver, Canada
Taycan4S
Depends... the offsets of the 971 Panamera wheels are slightly higher, by 11mm up front, and 3mm in the back. So that means they'll be set INWARD (into the wheel well) by 11mm and 3mm too much. You could probably consider 5 or 10mm spacers to bump them outwards to a stock Taycan offset, but you'll also need longer bolts. You'll also have to really make sure that there is adequate clearance inside for brakes and suspension.
I personally would not go that route. I will be looking at aftermarket wheels or OEM takeoffs. I'm sure someone will be trying to get rid of their OEM 19s or 20s soon enough.
Hope that helps.
