Query: Factory Taycan wheels weight? (OEM options)
arijaycomet
Ari
Cleveland, Ohio USA
Searched the forums, found no data. Does anyone know the weight of the various factory wheels. I'm personally most interested in the Turbo Aero Wheels (20") and the Mission-E Wheels (21") but would be happy to have all the data.
If you know the weight WITH tires, there are various sites listing the tire weights so we can do the math to work it backwards. In other words, weight of the wheels with or without tires is fine. (If you know weight with tires, please specify the tire you are running so I can find the mfg posted weight to do the math).
PS: I'm in the process of getting some aftermarket 21" wheels on my car. I have the 20" Turbo Aero wheels, and do hope to weigh the setups at some point (with tires) when I swap over. But that wont be until spring weather arrives, so 60+ days away still, sadly.
Thx in advance!
Genau
Reston, Virginia
Turbo Aero: 20x9" front and 20x10" rear wheels with 245/45/20 and 285/40/20 Goodyear Eagle, weight 257.2 lb. Source: @Adrian@GlasWerksDMV when his shop swapped out my Turbo Aeros for Forgeline FU3Cs.
arijaycomet
arijaycomet
Ari
Cleveland, Ohio USA
If Adrian has it, I'd love to know the weight for a front wheel/tire vs a rear wheel/tire. But for starters, this is good data. Thank you so much!
Persuader
2024 Taycan Turbo S Cross Turismo, 2024 Range Rover L461, 2020 Aston Martin DB11
Turbo Aero are 20x11 on the rear.
rs38
Düsseldorf
Taycan,GT2,i8,Tesla
front / rear
28,0 /30,1 kg : 21" Exclusive Design with Carbon Aeroblades and Pirelli PZero
27,5 /29,7 kg : 20" Turbo Aero with used 4000km Pirelli Eco Tire
(not too bad for the 21" wheels, as they have +20mm Rubber and +0,5J Aluminium, each front +rear)
