Question about estimated range remaining
SWORDER
2021 Taycan Turbo S
Context: 2021 Taycan Turbo S with 93 kWh battery capacity.
There are typically around 202 miles remaining when I charge to 100%. It's been like that for two years. So presumably my average consumption is around 2.17 miles/kWh.
After a recent 500 mile road trip with chilly temperatures, a fair numbers of hills, Sport Plus mode, and average speed of 85mph, charging to 100% now gives me 150 miles of range. Since the Taycan estimator's lookback period is 375 miles, presumably I was averaging around 1.61 miles/kWh for the last 375 miles of my trip.
Now I'm back home and am consuming a more typical 2.2 m/kWh according to the Trip screen. Yet the estimated range is still ticking down from 150 as though I were driving at 1.6.
Presumably this will self-correct over the course of the next 375 miles, but my question is this: If I were to drive exactly 150 miles (from 100%) at 2.2 m/kWh, the estimated range will presumably show zero, but will the car actually cease to function at that time or will it at some point realize that there's indeed another 50 miles available to me due to my more fuel-efficient driving style?
Archimedes
Monterey
The car will not show zero if the actual range is higher. As you drove, the range would not drop by as much as your actual mileage. It would continuously correct on the way down. I’ve experienced this multiple times on long drives.
B61
Bine
SI
SWORDER
SWORDER
2021 Taycan Turbo S
Just one note: you have PB+ with available 83kwh only.
Thanks for the correction. I was trying to backfill the m/kWh values so my example would make sense.
So the total available is 83kwh then, not 93. That's good to know.
