ST GTS w/ Active Ride: How does it compare….
mpaulus007
Michael
Germany
GTS ST
Thinking about switching from CT to ST GTS w/ Active Ride. Couple of questions:
- Ground clearance is 20 mm less than CT. Does Smart Lift go to same height as CT?
- Does comfort entry height adjustment go to same height as CT?
- GTS setup has a more rigid lateral stabilizer and adapted PASM for greater dynamics. Does this also apply for GTS w/ Active Ride or can I enjoy full range from comfort to sporty setup with AR?
Thanks for sharing!
ze_shark
JC
Southern Malaysia
You must be meaning J1.1 CT to J2.1 ST ?
I undersrand that the ride height of the CT is offset compared to the Sedan/ST due to different links, so logically, comfort entry and Smart Lift will not go as high as the CT.
J1.2 ST active ride owners report being happy with handling in Normal mode, but C&D and my humble self report disturbing behaviour with CT+PAR.
https://www.taycanforum.com/forum/threads/taycan-rws-issues.27406/post-419459
Handling in Sport/Sport+ is excellent on CT+PAR so i can only assume it is the same on ST, or even better.
