Try a 4S+ with the Performance options and then ask yourself if you need more power. A Taycan is much more than just straight line acceleration![]()
^ This. Whatever the option set you end up with, this is an awesome driving vehicle, lots of fun, looks really cool. They say happiness isn't getting what you want but is wanting what you've got. So get one then enjoy the hell out of the one you've got!Either way, once you are driving it, engaged on a challenging road, you will forget what you have and haven’t optioned. But, once you get on to a forum or a configurator or read another review, you will wonder if maybe you should have ticked that other box.
Just own it and enjoy!
But with the electric charging ports you have to have the vents blocked which make them fake vents.Great spec car, seems to be missing electric charging ports especially for such a high spec car
I thought the vents were blocked only when you chose Mission E’s. I don’t think it has to do with the charging port. With the Mission E wheels the air doesn’t flow over the surface of the wheel as much so the vent doesn’t function as designed.But with the electric charging ports you have to have the vents blocked which make them fake vents.
No. It's definitely blocked when you spec electric charging port whatever wheels you have.I thought the vents were blocked only when you chose Mission E’s. I don’t think it has to do with the charging port. With the Mission E wheels the air doesn’t flow over the surface of the wheel as much so the vent doesn’t function as designed.
