Taycan PCM Soft Reset - Solves A LOT of Issues
Lazy
United States
2020 Taycan Turbo
I'm seeing many posts about login issues, not seeing menu items, etc.
Every time I have a glitch, this is what I do and the PCM has corrected itself each time so far. Follow these directions exactly:
  1. On the top right hand corner of the main center screen, briefly press with two fingers.
  2. Dash screens (center main, lower center, and passenger screen if you spec'd it) will go dark for 30s to 1 min.
  3. You will see a red and black screen that says "Initializing engineering." Wait.
  4. You will then see a list pop up on the screen.
  5. Tap the last choice that says "Reboot to normal mode." Only pick this choice.
  6. The screen will then say "Really quit engineering?" Tap click on the bottom left.
  7. You will see a progress bar pop up on the screen. When that fills, your screens will go dark again.
  8. Wait until your PCM comes online. The screens will come back on and you should be good to go.
Hopefully this helps.
