ron_b
Ron
SF Bay Area, USA
Well I found this while checking Porsche site for Norway then changed it to the UK to get American figures (miles).
I find it very useful.
https://www.porsche.com/uk/models/taycan/taycan-models/taycan-4s/
Update - here is a link to the international page showing in of range but allowing display of range improvement with heat pump. Note that the UK where heat pump is in base configuration shows range as if heat pump is not used.
https://www.porsche.com/international/aboutporsche/e-performance/models/Either link scroll down to range calculation or indicator.
I'm sure European members already know about it, I had seen it mentioned but as it is not shown in porsche.com/usa I was not aware earlier.
Just select your vehicle type, battery size (if 4S), driving, outside temp, and Climate setting (I suggest ECO).
You can also look at impact of alternate wheel styles/sizes.
I am hoping that these numbers hold true then I will be ohh so happy.
HK111
Henrik
Germany
Hello there,
thanks for the very useful pointer. Indeed, if the numbers are true, we're in good shape. I am still wondering about the effect of "range mode", where the car uses only its rear motor. How big will that effect be?
And I wonder if we will ever get a software update that will allow something like "yes I know I am using more capacity of the battery than regularly allowed but it is important".
Cheers,
Henrik
BenJL
Paris
What does it mean "ECO PLUS" for section Air Conditioning ?
Singularity
Finland
MY 2020 Taycan 4S, MY 2022 Audi Q7 60 TFSIe
The Taycan has 3 settings for A/C. It's either OFF, in ECO PLUS, or ON. The Eco Plus mode uses significantly less electricity compared to having it fully on. I have not seen any reviews mentioning how good the Eco Plus A/C is. Hopefully we get some info on that from someone soon. It would require warm weather to be able to comment on that though.
ron_b
ron_b
Ron
SF Bay Area, USA
Henrik,
I would guess these ranges are while using Range Mode, not Normal and certainly not Sport. I would personally be fine with that if they are indeed attainable at the various temperatures.
The other thing I saw on a video and on a graph is that the Taycan goes into limp mode at 0% implying there are some miles beyond that with restricted performance.
Also saw in a video that even in range mode if you punch the accelerator that it will kick up the power to accommodate (good for passing).
Reg
West Coast, The Best Coast
when it is 20 Celsius outside, having the A/C on makes a difference or 42 miles of range?
What exactly is the A/C doing given that it is not that warm outside?
Note also, that the difference between it being a comfortable 20 outside and a blazing 35 is only 4 miles of range. Not sure how accurate this will be. probably way better at 20 and far worse at 35.
ron_b
ron_b
Ron
SF Bay Area, USA
I know that they call the option A/C but I assume that they mean HVAC so at 20C they would be talking about heating and my experience is that heating takes a lot more power than cooling in an EV.
Note: The Taycan can heat cabin utilizing residual heat from motors so that should be some savings, better than a Bolt EV for example.
Singularity
Finland
For heating it will also matter a lot if you have the heat pump or not. It's a super must have accessory if you're living in an area with cold weather.
Reg
20: some heating - range 220
25: no heating, maybe some AC: range 220
35: no heating, lots of AC. range 224
That is just odd.
Reg
Is that an option in Europe? I don't believe it is an option in the US, so is it standard, or is it not available?
ron_b
ron_b
Ron
SF Bay Area, USA
I had read that it was a free option in cold countries. I see that in Iceland you can select Heat Pump under E-Mobility at no charge for example. I believe also in Canada and Netherlands.
Singularity
Finland
Interesting. Here in Finland the heat pump was an 800 € accessory. And this is a country where almost every buyer will likely choose it. Well I guess it's an easy way for them to make some extra money :D
Reg
I am still not clear on the heatpump for the US. Is it standard, or not available (since it isn't an option). we do have places that are cold, but not as bad as Norway ;)
ron_b
ron_b
Ron
SF Bay Area, USA
I read that it was not an option for the USA. I agree we have some cold states like Michigan and Maine, I think folks there can maybe work through their dealership if they feel motivated to get it. But I would say the Porsche answer will be 2Q or 3Q for that to be offered for US customers.
Probably Porsche is strained enough with all the country localization issues with the launch.
cometguy
New England, USA
2018 Panamera 4 ST E-Hybrid; planned Taycan CT4
Hello there,
Cheers,
Henrik
I, for one, am hoping that Porsche will allow us to choose when/if to do software updates. I keep hearing these horror stories about automatic over-the-air software updates by Tesla that causes problems for their owners. I would like the option to have external access to my car's computer turned off unless I say it's ok -- after I've had a chance to review what software updates they are proposing and why.
