TSB: Re-Programming Battery Sensor Control Unit and Electronic Air-ConditioningCompressor Control Unit (WNV0) June 30, 2023
The battery sensor control unit and/or the electronic air-conditioning compressor control
unit was not programmed automatically as part of the VR19 update due to a fault in the PIWIS
Tester release 41.300 in the affected vehicles.
Measures: • Re-program the battery sensor control unit and/or electronic air-conditioning compressor control
unit with the latest PIWIS Tester software version.
https://static.nhtsa.gov/odi/tsbs/2023/MC-10238808-0001.pdf
rs38
Düsseldorf
Taycan,GT2,i8,Tesla
did anyone try to check the new versions of both ECUs and if VR19 has actually affected it?
VCDS:
0117 is the version of A/C compressor sub:
Subsystem 2 - Part No SW: 9J1 816 797 B HW: 9J1 816 797 B
Component: J842 EKK es33 H05 0117
and it was 0116 before the big update last year.
cannot find an ECU called "battery sensor"...
