Wheel Change Detected
DanH23
Newport Beach
This noticed came up yesterday after leaving parking garage. Prior to tire pressure was 30 front, 41 rear. Checked tires pressures all ok. Message won’t go away and car won’t read tire pressure. Any thoughts?
r553
Rockledge FL
If you go into the tire menu and change tire size and then return to the correct tire size that should trigger TPMS relearning. You'll have to drive to get it to acquire the tire pressure data. I have gotten this with change of seasons ( temperature ).
4sCT21
Nottinghamshire
W205 C63, to come 2024 Taycan RWD
I've had this message a couple of times today, post washing my car. The tyre pressure readings seem a bit erratic as I'm driving along.
I changed my tyre settings earlier (as a result of this, prior to coming on here), and then switched them back again, but the next time I drove the car, the message came back.
This time I've tried changing the wheel size and rest back, let's see what happens.
