Dee
- Dee
- Dec 14, 2018
- The Netherlands
- A lot
- #1
Looking at the graph at 9:53, isn't that indicating peak 725ps versus Porsche's stated 761? Sorry I don't understand German, I guess the answer is in the narration...
At least there's more power than Porsche states (not really a surprise but still, it's a lot more).
Jeremy Clarkson would be so proud of you!I know all this, I am an engineer who worked in Formula 1 for over 30 years.
Power is what actually does the work and, yes, it is calculated from torque and speed.
Two hypothetical engines, one with twice the torque but at half the rpm as the other have the same power, and, geared to do the same speed, the thrust at the tyre is the same for both because it is power, not torque that counts.
One of my old friends was technical director of the Ferrari F1 team. If an engineer came for a job interview his first question was always “which is important torque or power?” If the candidate answered torque the interview went no further.
It is a common mistake made by non-engineers and a disappointing number of people who think of themselves as engineers.
So it's 725ps to the wheels without launch control?No, it's 761HP with LC, normal is 625HP (like the Taycan Turbo).
They test without LC (you can't actually test LC on a dyno).
That's nuts! I wish there was a way to Dyno with LCYes.
Isn't it 657 ft-lbs?The gearbox of the taycy has a short planetary first gear (15.5:1) providing maximum acceleration, and a long-ratio second gear (8.05:1) delivering top speed and efficiency.
Can you guess the actual torque at the wheels?
You're a mad man.I assume you want overboost ALL THE TIME!
And on that I'm already have contact with a car turner here in the Netherlands to deactivate the 2,5 second limit of the full power.
I am happy to take Frank's word on any of the technical gubbins on here.I worked for several teams starting with Hesketh racing in the mid-1970s and spent longest at Williams, there were 23 of us when I joined.
I see you are from the Netherlands. I was chief engineer at Benetton when Jos Verstappen was Michael Schumacher’s team mate and have known him and Sophie since before Max was born.
I have teased Jos that Max is really Belgian since he was born in Belgium and his mother is Belgian. ?
He doesn’t think it is a funny as I do.
NO. RPM does not generate torque. There is a bit of confusion going on here.The first thing you need is rpm to generate torque (torque = force x radius -> power x rpm).
Was exactly right.It isn’t the power that maintains the torque it is the torque being maintained at high rpm which gives a lot of power![]()
I don’t understand what this question is asking.Ok, here's one for you: what dimension is horsepower in this equation?
Do you mean this?Ok, here's one for you: what dimension is horsepower in this equation?
Amazing to hear from someone who was in the thick of that season - arguably changed F1 like no other.I was chief engineer at Benetton when Jos Verstappen was Michael Schumacher’s team mate and have known him and Sophie since before Max was born.
Actually, three of the current F1 drivers have a Belgian mother: Max Verstappen, Lando Norris, and Lance Stroll.I worked for several teams starting with Hesketh racing in the mid-1970s and spent longest at Williams, there were 23 of us when I joined.
