ATLANTA AREA Car charger install
RBGtaycan
Bob
Long Island, New York
Has anyone in and around Atlanta used Car Charger Specialists for their NEMA and charger mount install? Do you have a recommendation on who to use for this? Thank you!
https://www.carchargerspecialists.com/residential
Pretty much any electrician ought to be able to install. Especially if you are simply putting in, for example, a NEMA 14-50 plug (that you plug your "charger" into). Just ask the electrician to be sure to use an EV rated plug such as a Hubbard (a little heavier duty). To be honest, you don't even have to use the words "EV charger" w/ the electrician: just say NEMA 14-50 heavy duty. A good locale is near the garage door so you have the option to charge outside as well as inside with a 25 foot cord
trycan
Agreed. Any electrician is able to perform the work and you don't need a "charger specialist". Probably the biggest challenges/questions are:
* Do you have room in your panel for the 50 Amp breaker?
* How far is it from the panel to the place where you need the charger?
Depending your situation, if you're doing a garage install, I would recommend putting the NEMA 14-50 *and* charger on the ceiling. It keeps the cord up off the floor and can more easily reach all corners of car, in case you want to charge something other than a Taycan someday.
