Charger Installed!
Gogs
Gogs
Gordon
Aberdeen, Scotland, UK
Where does the intelligence sit when you use a Porsche charger/connect app?
I.e.does the app tell the car to pull load from the charger or does the app tell the charger to Push load?
just thinking if I switch to zappi as the charger can you still setup charging profiles in the Porsche app or do I use the zappi app to set charging times?
You would control charging via the Porsche app/car. The zappi app lets you see consumption in your house and the output to your car. You can set timed /delayed charging but I’d let the car do that.
7upMan
Mat
Porsche Taycan Turbo
Hi, I have the exact same charging units you, but my Taycan will not charge when I use a profile timer, i.e. only charge between 00:00 and06:00.
Does that work for you?
