Clicking Sound From the Rear
jimshadow
Jim
Indiana
2020 Taycan 4S, DB9, 599, Denali, X1, Tiguan
Past couple evenings when I get home I’ve noticed a rhythmic clicking sound coming from the rear right (drivers side) wheel well area. Tonight, I plugged the car in after being home for a few hours and there it was again. I DO have a ‘suspension error‘ light that has come on several times over the past week and it’s going to the Dealer on Monday AM, but that warning light is not on currently, nor is any warning light for that matter.
Thoughts?
Jim
NC_Taycan
Lewis
Wake Forest, NC
Pressure or position sensor error, or air leak in the pneumatic shock on that corner.
JonasOfNorway
Jonas
Norway
Taycan 4s
Thoughts?
Jim
Jim, did you get any info from your dealer about what was making the sound?
jimshadow
jimshadow
Jim
Indiana
YES! It’s a fairly common problem that the wiring harness back to the suspension pump is not properly routed from the factory. The air hose gets pinched as the car moves up and down which causes the pump to run continuously. This is what happened to my car most recently. They ordered a new section of the wiring harness and re-routed it so its out of the way, hopefully for good!
bosch88
Andy
Vancouver, BC Canada
2020 Porsche Taycan 4S
I have the same issues... its like a ticking clock in the rear driver side wheel well... the cars is in the shop... let's see what it is... but probably is as described above...
Chedman13
Illinois
GL63 Brabus B63 Widestar, Awaiting Taycan Turbo
@bosch88 any update you can share? I have the same issue... first day with the car.
Chedman13
Illinois
@jimshadow - do you by chance have a copy of your service order so I can show that to my service advisor? Thanks!
rpkgator
Roger
LA
2017 Macan GTS
Sounds like you all may have figured it out. I had a similar problem but only when the car was moving. Turns out if you have the "bladed" wheels the blades can come loose and click as the wheel turns, so another possibility to consider.
bosch88
Andy
Nope... it now can come from either side of the car... tick tick tick... the dealer said it was the security system checking if the doors are locked... I'm not sure, but it still happens...
Chedman13
Illinois
Mine does it constantly on both sides of the rear...
