Driver Profiles-Newbie Question
Taycan191
2019 Mercedes CLS 450 Edition 1, 2Taycan (Ordered)
Just picked up my Taycan yesterday. Is there a way to set a driver profile where certain features in the car activate upon entry or starting the car. e.g.-sport sound, I find I'm having to manually go into vehicle on the main display and turn sport sound on each time I start the car up. Is there a way that I can always have this on? Same with A/C recirculation, is there a way to have this always be on? We set up a user profile, but that was for Porsche Connect and didn't have options to select car settings.
Thanks.
Hirschaj
Jim
Austin TX
Thanks.
Nope, those settings don’t get saved when you turn off the car.
Thanks.
If you have Sports Chrono then you have a drive mode called Individual. Use this setting to store various car settings such as electric sports sound, chassis height, PASM settings etc. On power on simply dial up Individual on the steering wheel.
Auto air recirculation when set in PCM to on should be remembered by default. At ambient temps below 5C the feature is disabled to prevent screen misting.
If you have driver memory and / or comfort option then many settings from AC, seat, steering wheel, radio, PCM etc will be memorised. These are assigned to the key fob and Porsche Connect ID.
