SnowMan
- #1
Hello
Im a new user of a Taycan. Have Porsche Approve Warranty. Buy a OCB dongle, MC+ and use it with Carscanner.
Have a lot of error code. I call PC and they say the only cares of when the codes ar active. They also say it's a complex car and computers in the car so it is some error code all the time. As long as their not stays it is not anything to worry about. Their words. Is it right? They also say.. if you have problem with things not working properly in driving, or errors in the display. Then you can come in.
I feel the temperature is not going up so quick when driving around in sport plus. With zero degrees outside.. a runin 15 minutes not rising the temp it stays at 4 degrees. But, when Ipark the car in Sport plus it can go up in 25 minutes from 0 to 15 degrees.
My consumption is high..Around 30kwh/100km (its 2.071237 mi/kWh) when driving 20km (13 miles). Slow calm ride for 35 minutes.
Can I have problems with the fans to the battery in right and left wheelhouse?
This error code is for me most concerning, note I done the readout today 250209:
60023 [0x00EA77]
P2D3800: Hybrid/EV Battery Pack Heater Performance
EA77 Hybrid/EV Battery Pack Heater Performance
Status bits: 1
Priority: 4
Frequency: 3
Unlearning index: 255
Odometer: 30068 km
Date, time: 2025.01.27 13:09:24
Paramteric values: 20 96 28 4E D0 FF FF 07 03 1D 01 00 FF 05 00 FF 06 00 FF 00 00 FF 34 A9
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear"
I but the complete error code list as an attachment.
60023 [0x00EA77]
Status bits: 1
Priority: 4
Frequency: 3
Odometer: 30068 km
