How many Miles per KW are you getting?
J0EL
Y1ADB1
2021 Taycan 4S
Do your miles per kw get better with time?
How many miles per kw are you getting? I'm getting 2.96 miles per kw
How many miles do you have? I have 1742 miles
How many amps do you use to charge? 24 amps
My avg E-consumption is 2.7
My max E-consumption is 3.4
schad
Northeast
Taycan 4S, e-tron
Mine got better over the first couple hundred miles, but it's been pretty steady for a while now.
When I am taking my son to school, I get 3.2 mi/kWh. When I am coming back from dropping him off at school, I get 2.6 mi/kWh. Sport Plus at highway speeds is fun but hard on efficiency.
My range at 80% SoC is 222 miles -- a nice easy number to remember. That works out to about 275 miles at 100%. EPA's ratings are an absolute joke; I could top 300 miles if I tried. I use about 22% charge a day. That works out to 61 miles, which is pretty darn accurate.
I use a 48A EVSE, and, the official 9.6kW charge rate notwithstanding, I get about 10.5kW. I have pretty low voltage at my house, so that probably truly is 48A. I don't need that much juice, but it made sense to do a 60A circuit since it was all new wiring anyway.
NC_Taycan
Lewis
Wake Forest, NC
32 - 40 kWh/100 miles. This comes out to 2.5 - 3.125 miles per kWh. Turbo with Mission E wheels. When you first start driving in Sport Plus, your efficiency will suck because the battery is being pre-heated to a more optimal temperature. Best range I've seen is 256 miles. I usually figure 200 at 80%. Take away 20% range when it's cold (< 30 degrees).
Soxmandan
AZ
3.1 mi/kWh on the 2022 4S, with 14,765 miles
