How to identify small vs large battery in Taycan 4s?
psalomon
Pablo
Montevideo, Uruguay
Mercedes 350e
How can I know if a Taycan 4s is equipped with the small (Performance) or the large (Performance Plus) battery?
a)Is the total capacity of the battery visible somewhere on the Infotainment screen?
b)I understand the trunk is smaller with the large battery. Anyone has pictures showing the difference?
c)Any other way to identify this?
Thanks,
Pablo
Jancha
Janis
Latvia
911 Cabrio (ex Taycan 4s+)
Thanks,
Pablo
measure 0-200km/h time ?
4SJB
Jonathan
Taycan 4SCT Mini Cooper S Audi A4 3.0 TDI
Not So:
Acceleration 0-99 mph (0-160 km/h) with Launch Control (Performance Battery)8.7 s
Acceleration 0-99 mph (0-160 km/h) with Launch Control (Performance Battery Plus)8.5 s
Acceleration 0-124 mph (0-200 km/h) with Launch Control (Performance Battery)13.3 s
Acceleration 0-124 mph (0-200 km/h) with Launch Control (Performance Battery Plus)12.9 s
GTS ST, Macan T
The vehicle VIN number will hold the key to this. Also you should be able to get a list of all option codes on any given vehicle. Performance plus has the code J9K (93kWh battery).
Also check max charge. In UK at this time of year expect 220 - 230 miles on a 100% charge and less than 200 with a non performance plus battery pack.
jetbox
Scotland
Yes
No difference in boot size either as the extra battery cells are under the rear seats not in the boot. ( the boot size changes with bose)
Dr Chill
South FL
2020 Taycan 4S, 2008 911 Turbo, 2009 911 Turbo Cab
Trunk size is smaller in the Turbo variants due to the larger rear motor.
andyxxl
andy
97080 germany
Taycan 4 S
I thought this depends on the woofer from the Bose/ Burmester soundsystem.
So if you opt bose for a 4S your Trunk will be smaller.
