Is this too slow?
Ll312
LL
Chicago
Taycan, S7, Q8
I’m sitting here at a EA 150 kW station and going at 53kW. I preconditioned and got the battery to 89F and ambient temperature is 37F. Battery at 15% when I started.
I’ve charged at this location in the past and have gotten up to 130kW and I’ve been able to charge as fast as 200kW in the past at a 350kW station. I’ve switched stalls and got similar charge rates.
The polestar next to me is going at 67kW and beating me :(
After preconditioning and arriving at a low soc I expected at least 100kW or more, am I wrong?
Archimedes
Monterey
I find that it’s somewhat random based on the local infrastructure power availability and the presence of others charging at the location. Don’t think it has anything to do with your car.
Hirschaj
Jim
Austin TX
89 is not very warm for being preconditioned. Should be closer to 110 IIRC.
Archimedes
Monterey
I was told 70-90. I’ve repeatedly charged in the low 90sF and still didn’t get super high speeds, even at low SOC. The kWH stated on the charger is meaningless if the site isn’t getting the power to begin with. Twice I’ve gotten a message saying ‘charging reduced due to load balancing of infrastructure’.
Uknown
Sam
US
Taycan 4S MY20
Any chance the chargers were shared? I have been to a couple that are shared power between 2 chargers. I would start off near 150, then some one would pull in and I would see it drop as they used a chunk of the shared power.
Hirschaj
Jim
Austin TX
When I charge at high speed my battery temp starts in triple digits.
xyeahtony
Tony
Baton Rouge
23 Integra 6MT, 23 CT4S
If you're not starting in triple digits unplug and try a different pedestal.
32C is about right but remember that regardless of whatever temperature your battery is at when you start the charging session the early stage of charging will raise the temperature to what it determines as optimum. This typically only takes a few short minutes.
Likely explanation is local infrastructure limitations, loading, throttling by the operator and so on.
