WattTurbo
- Kevin
- Nov 13, 2021
- Katy, TX
- 911 C2S, Taycan Turbo
So if we have a tune and can do a virtual LC at will when those conditions have not been met, specifically the gearbox and battery temps, then we could potentially harm those components?Looked up the conditions in ASG out of interest:
* Steering straight
* Hard on the brake (there's a minimum brake pressure, which is pretty high)
* Throttle >99%
* Car stationary
* Gearbox oil temperature between 10C and 100C
* Gearbox clutch temperature between 8C and 200C
And then you also have the release conditions in the BMS, which is battery temperature and state of charge.
