Some bugs…any tricks?
miglio
Italy
Taycan 4s - Cayenne Coupe Hybrid - Carrera S 992
These bugs were on my Taycan 4s and now on my GTS…
Two of these…
AC SYNC doesn’t work for days, after some it start to works well…
In the display option I try to uncheck Standby mode for passenger display, but I cannot uncheck…sometimes works (when AC SYNC works) sometimes not (exactly when AC SYNC doesn’t works)
Can you help me? Are these classic bugs or someone can tell me a trick to solve it without wait days?
Thank you guys
raharris
A lot of issues can be solved with either the engineering reset,12v battery disconnect or pulling PCM fuse.
I’ve had that clear other issues; not experienced your one.
miglio
miglio
Italy
i have tried only the 2 fingers in corner and after press quit…nothing solved
12v disconnected or pcm fuse never tried…where they are ? Easy ? Thank you
raharris
PCM fuse is easy; check the manual it’ll tell you exactly which one - memory serves me it’s the right hand side in the trunk.
I haven’t done the 12v battery disconnect but someone recently posted their experience with doing this with step by step.
miglio
miglio
Italy
thank you so much
it’s very ironic because if I do nothing in some days or hours it solves himself…like the car is alive
npx
Justin
Cupertino, CA
2020 Taycan Turbo
AC sync bug seems to happen after using remote pre-cooling. increase passenger temp by one degree, then press sync. works for me.
miglio
miglio
Italy
I use everyday precooling
Tomorrow i try as you told me … probably you’re my man
thank you mate
npx
Justin
Cupertino, CA
2020 Taycan Turbo
thank you mate
any time - hope it works.
dumb bugs like this don't bother me. if one leaves me stranded, then I'll get worried.
