Using an old rarely used charger
senwar
Paul
Sheffield
MY24 ST GTS
I pick my CT4 up tomorrow and am having an Ohme Home Pro fitted on 27th (didn’t expect car as quickly).
I have a Rolec 32 amp charger I had installed in January 2016 as I had a Golf GTE company car at the time. I only used it about 5 times and got rid of the Golf in 2018 (hated it). The charger has been used once since about 3yrs ago to help a neighbour diagnose a charging problem.
I feel too nervous to use the charger on a new car - am I being silly? Or will it be ok until I have the new one fitted?
Dublin, Ireland
www.targatrips.com
Defo being over cautious. The thing to remember here is that they are not "chargers". They are just a socket – with a relatively primitive control protocol (based on electrical resistance).
The charger is in the car – and it is its job to protect the car from any electrical situation it is not happy with.
Even though "chargers" – technically called EVSE's – come with ever increasingly fancy features – the basic function are all the same. Despite all the features, the EVSE contactors are either open (on) or closed (off).
PIN control, RFID card control, timers, data logging, online connections, etc – all add functionality – that you may or may not value – but it is all just wrappers around a socket with a switch!
Your 32 AMP Rolec will supply power just as well as the one you're waiting on – especially if you only have a single phase supply (which is typical in UK and Ireland).
Plug it in!
Is it hardwired? Was is professionally installed? If the installation is solid, there is nothing to worry about. EVSE’s are just glorified extension cords with GFCI built in, there isn’t much a an EVSE (AC charging equipment you call a charger) can do to damage your Taycan, unless it melts or catches on fire.
An actual DC charger is a different story, but back in 2016 they didn’t have residential options so what you have is definitely an EVSE.
Dublin, Ireland
www.targatrips.com
Is it hardwired?
To the best of my knowledge – EU* wide electrical regulations insist on all EVSE's being hard wired back to a dedicated fuse in the distribution board. With an emergency switch off installed between the EVSE and the fuse – located beside the EVSE.
The NEMA stye sockets being a completely alien thing over this side of the pond.
* – And UK was EU back in 2016.
There should be no reason not to use it - all are compatible. With a 32A setup you are set for 7.4kW home charging.
Just check that you don't use any programme features of the EVSE and rely exclusively on My Porsche app for timed charging.
senwar
senwar
Paul
Sheffield
MY24 ST GTS
Thanks all - that makes me feel a bit more comfortable - and especially making me realise its just a fancy plug
Plug it in!
Thanks - that makes sense - and I'd not even thought/considered that its just a socket, and that's absolutely right. I have no issues using plugs in the house that are infrequently used. Thank you
senwar
senwar
Paul
Sheffield
MY24 ST GTS
Is it hardwired? Was is professionally installed? If the installation is solid, there is nothing to worry about. EVSE’s are just glorified extension cords with GFCI built in, there isn’t much a an EVSE (AC charging equipment you call a charger) can do to damage your Taycan, unless it melts or catches in fire.
Thanks - yes hardwired and installed by EV Solutions. Appreciate the reply
senwar
senwar
Paul
Sheffield
MY24 ST GTS
Thanks also - yeah will just use the Porsche app for the moment. I'm switching over to OI once the Ohme is installed
RGBArgee
Rick
Somerset and Brittany
Taycan 4SCrossT.992 Turbo S.Audi S3 8Y, MG Midget
Think you are being silly!
bn8959
Ben
UK, South West
Taycan GTS ST (MY24)
Note, you dont need Ohme EVSE to switch to OI, Octopus supports the Taycan directly, so you can have any EVSE.
senwar
senwar
Paul
Sheffield
MY24 ST GTS
Ah right thank you. I’ll try and sort it this weekend then. ?
