Skier
Marc
New York
2020 Taycan Turbo
Porsche Wall Charger Connect
$1,586.00 $1,269.00excl. Tax
$1,269.00 instead of $1,586.00 excluding Tax
Sold by Porsche Cars North America, Inc.
An easy charging solution for your home, with a charging power up to 19.2 kW(AC)*.
I have a 2020Turbo which had to have the wall charger amp rate reduced so it now takes 12 hours to fully charge without disconnecting.
Am I to believe that rather then fix/replace the original paid for charger they want to sell me a $1,269 replacement.
What am I missing? This can't be the way Porsche thinks its fixing their problem. Really dissappointed. Comments?
JayGT4
Jay
CA
GT4 / Taycan Turbo
Does this offer any different / better charging than the Porsche Mobile Charger Connect that came with my 2000 Taycan Turbo?
Skier
Marc
New York
2020 Taycan Turbo
twice as fast as the original was until they downgraded it !
Jeremy
St. Louis, MO
2022 Macan S; 2021 Taycan 4S
This is a different unit that is hardwired and charges up to 19.2kW. It’s been out for a while (> a year). It’s not related to the PMCC issues.
The mobile chargers were reduced. Not the wall charger.
Jeremy
St. Louis, MO
Up to 19.2kW, but you have the have the supply capacity for it and the car has to be able to accept it. 19.2kW AC charging is an option for the cars (not available in the 2000 model year ?).
Standard AC charge rate maxes out at 11kW.
JRNJTAYCAN
Joe
NJ
22 Ferrari, 22 Q5, 2015 Titan, 2015 Wrangler
This is bull crap! They cut our power in half then they throw this in our face to buy a unit that can charge from 0 to 100% in 5 hours BUT......they want us to pay $1,269.00 more.
They should be giving us this unit to replace the crap we already paid for when we purchased our car. I can't stand corporate greed!
JayGT4
Jay
CA
GT4 / Taycan Turbo
Ah thanks for the clear explanation @Jhenson29! So with the Porsche Mobile Charger Connect cable that came with my 2000 Taycan Turbo and a NEMA 14-50 plug in my garage, what kW rate am I charging at home?
Jeremy
St. Louis, MO
9.6kW max per specs. Which is half of the 19.2kW rate.
Just remember, the car needs to be able to handle the rate also.
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
At 100%, 9.6kW (mid to high 8's at the vehicle side.)
At 50%, the new default, half that.
JayGT4
Jay
CA
GT4 / Taycan Turbo
Gotcha. What max kW charging rate was the 2000 Turbo able to handle? (since the 19.2kW option wasn't available yet)
Jeremy
St. Louis, MO
All Taycans have a standard max rate of 11kW (specs state 9.6, but users have observed the actual to be 11).
2021 introduced the 19.2kW on-board AC charger as an option. It’s also available as a retrofit now, but it’s expensive. @daveo4EV had a thread & post about it:
Links:
For What it's worth - 19.2 kW Retrofit cost in US
19.2 kW charger will see very little use in North American unless you spring for an expensive 240V 100 amp circuit for your home charging situation
Tazboy81
Washington DC
G550, RR, Taycan
Oh is that why my car all of a sudden started taking almost double teh time to charge?? i was wondering what happened.. i am getting about 4.5KWH/hr..
I have a 2021 with extended battery, so that mean the new can charge my car in 5 hours in real?
