bootsie
- Steve
- Aug 16, 2020
- Northants, UK
- Taycan Turbo, Golf GTI 16v
- #1
Are there any dashcam users with a rear camera installed in their Taycan?
Have you had an problems with radio reception?
I've had issues with both DAB+ and FM radio reception since my dashcam was installed. i finally tracked the issue down to the rear camera causing the interference. My camera was installed right at the top of the rear screen and the cable routed behind the headlining. I assume it's EM interference from the camera.
Once I removed the camera (and the cable) the radio sprung back into life.
Right now the camera is about an inch down from the top of the rear screen and the cabling is sort of dangling there - luckily the rear visibility on the Taycan is so bad you can't see it in the rear view mirror!
Just wondered if anyone here has encountered the same issue and has any solution - like some sort of shielding for the cable perhaps.
