Anyone experience buzzing from steering wheel
Jamesfawcett
Yorkshire
2020 Turbo S
Thank you! I've just sent that exact link to my service advisor :) I sent a previous TSB that someone linked to, but it didn't apply to my car because mine has PCCB. The fix from the other TSB was dampers added to the steering column. Mine does feel like it could be a wheel bearing, but I thought if there was play in it they would have found that on inspection. I'll post back if I have any success.
Jamesfawcett
Yorkshire
2020 Turbo S
TSB: Taycan: Buzzing noises from the area of the steering column - May 5 2022
Condition: The customer complains of a buzzing, vibration, or rattling noise from the area of the steering column.
Technical Background:
There are various potential causes for noises to be transmitted through the steering column and into the cabin. This document focuses on noises associated with faulty wheel bearings.
https://static.nhtsa.gov/odi/tsbs/2022/MC-10213069-0001.pdf
Also search list of Taycan TSBs compiled by @rs38 for 'noise': https://ti-list.azurewebsites.net/
Hi Tooney,
My OPC called me and said they have no record of that document at all, they said it might be because it's overseas (I'm in the UK).I mentioned the document has Y1A on there and mine is that model. They also said they don't have that equipment.
It matches my car's symptoms exactly. My car is going in for a test drive with the technician on 7th June for them to try diagnose again.
It's been a year now since I've been trying get this sorted and the vibration/buzzing has got worse.
Will reply with update if I have any luck.
Hi Tooney,
TSBs Porsche sends to NHTSA are manufacturer communications to US dealers and recalls for US VINs. May or may not be sent/apply in other countries. In a couple of cases campaign codes for same problem have differed between countries.
Good luck on resolving the problem.
