Anyone using ChargePoint Flex?
db4snyc
Den
New York
Hi there - just got a ChargePoint flex charger for my ‘21 4S. I can’t seem to stop it from charging to 100pct? When I have the timer set in My Porsche it doesn’t charge, and when I disable the timer it goes to 100. Any ideas?
JIP1080
JP
Atlanta, GA
Taycan GTS ST
Set a profile with a minimum charge value you want as a "max" instead of a timer. Do NOT set a timer. It *should* charge to that value and then stop. Counter intuitive I know. I found this deep in a charging thread here a number of months ago and it's worked for me.
If you do want to hit 100% at some point, set a timer for departure and the car will charge to the minimum, pause charging, figure out roughly how long it'll take to get to 100% and start charging again that amount of time before you leave.
You should be using a profile and timer to control both target charge and ready by time.
If you have timers or other programming set in your EVSE then disable any and all - set to 'dumb' mode - using only your My Porsche App for Profile & Timer settings.
db4snyc
Den
New York
Worked - thx!
