Brake Pad Indicator
Remedy234
Sheffield
I suspect my pads need changing, I’m getting a slight “wearing” noise not a grinding or squeaking but I would have thought they’d be some kind of warning light?
Bennachie
God's own county..
Taycan 4S Cross Turismo
There is a warning light BUT as the mechanical brakes are only used primarily at less than about 10 mph, unless high g stopping, I would be amazed that the pads are worn. Quite common on carbon to have noises.
SergeyIndy
Sergey
Indianapolis
What kind of brakes do you have Steel, PSCB, or PCCB?
How many miles you have?
Do you think you are using physical brakes a lot?
The PSCB are known to create noise as if they need new pads under certain conditions.
