Changing kmh to mph in ACC display?
Doc Sportello
CT4
Anyone know how to do this? Definitely have mph selected as the speed unit in settings, but the ACC "dial" that shows set speed and current speed in the first tube seems to show kmh?
Hirschaj
Jim
Austin TX
Mine randomly shows one or the other depending on how it feels that day. I believe this is another software glitch that we have no control over.
Sparky
Joe
Norfolk, VA, USA
2022 CT 4
I had the same problem. In the settings, I switched from MPH to KMH, made sure that setting took in the instrument cluster, then switched back to MPH. While counterintuitive, it worked and has stuck for several months.
Doc Sportello
Doc Sportello
CT4
I'll try that - thanks!
jvincent
SF Bay Area, CA USA
Ice Grey CT4
I've had the issue persist for my 5 months with the vehicle. Toggling the Units works for me, but it doesn't stick when the car is restarted. It is especially vexing that you can't change the Units setting while underway.
FWIW, I noticed two days ago that French was selected (along with English) on the Keyboard settings. I deselected French and left it only English. Today, for the first time ever, the car woke up with mph indicated. I'm willing to try anything at this point, but the French keyboard selection was odd.
trebzz
marc
ireland
Taycan Turbo J1.II
Hey just curious did you ever resolve this? When you say "toggling the units works" does this change everything to KM including the speedometer?
jvincent
SF Bay Area, CA USA
Ice Grey CT4
If I recall correctly, the big PCM update that occurred in 2022 fixed the issue. What I meant by "toggling the units" was to change the settings in the main settings menu which would shift everything to metric and then back.
