MarbellaClub
- #1
For some reason charging at home almost never works on the first attempt when connecting the charging cable to the car. It says (translated from Swedish to English) "The charging process has not been authorized, please remove the cable and reconnect". If I then remove the cable and reconnect it works.
If I've tried charging at home 10 times so far it have worked on the first attempt 2 times, the other 8 times have required a second attempt. It doesn't matter if I use the left or the right side.
Charging at Ionity and other external charging stations have worked every time.
It looks like there is a problem either with the charger (Porsche Mobile Charger Connect) or the car. Has anyone else experienced the same problem?
