Charging issues in DC (Electrify) and AC
AnloTaycan2022
Canada
CT 4S 2022 and now 2026
Has anybody got this problem and if yes, how did it get resolved? My AC charging is limited now to 9KW when I was charging in the past at 10,5KW and when I try to charge at Electrify, regardless where I go, I get limited between 65KW and 75KW maximum, regardless if the battery is very low, pre-conditioned etc.
gtm
George
Jacksonville, FL
Regarding the 9.6kW charging (I'm going on U.S. specs here), 9.6kW is at spec. I was able to charge at 11.5kW when I first got the car. Suddenly after having the ARB6 battery monitoring software installed I was capped at 9.6. Checked my purchase docs and listed in the specs is A/C charging at 9.6kW. Seems the higher rate might have been unintended? The software put the A/C limit back to spec. There is at least one thread on the forum about the A/C charging decrease after ARB6 or 7 was performed.
Regarding Electrify? If Electrify Canada is performing the same way Electrify America is (generally failing to varying degrees) then the de-rating is not unexpected. Grid limited due to the cold? You don't say if you have tried non-Electrify stations. Doubt it's your car since it is charging on DC.
AnloTaycan2022
AnloTaycan2022
Canada
Hum..... My specification on my car built was a 11KW charger. If my memory serves me right, they may have been on the first built (2019 - 2021) only a 9.6KW charger. I had never rechecked the charging rate in AC in a while and only did it because of my DC charging issue. I suspect like you however that the ARB6/7 is the issue on the AC side. I have checked with Porsche Canada and they cannot de-install that software module even. As for the DC, I have charged several times in winter and never got any isssue before. This time, I have tried at different Electrify sites at different times and it remains an issue. I have an appointment with Porsche on Monday. They do have 800V chargers on site, so we will see what they conclude. Thanks
Reactions: gtm
