Charging taycan 1 phase
dmislovi
Davor
Croatia
Mobile Charger Plus oem cable
Will the cable 1 phase 32A / 250V work if I have a power connection 1 phase 25A / 250V - approx. (5 kw)
You should expect the maximum of 7.4kW on single phase 32A and around 11kW on three phase - 220 / 240v from The Porsche Mobile Charger Plus.
A higher rated cable shouldn't limit what you can expect.
Consult a qualified Electrician for your specific scenario and remove the guess work.
dmislovi
Davor
Croatia
Can I charg 1 phase 25A with 1 phase 32A / 250V oem cable or mobile charger plus recognizes that the current is not 32A and does not allow charging.
25A is about 5kw and that would be quite enough for me.
Dublin, Ireland
www.targatrips.com
Lower current/amps is fine.
dmislovi
Davor
Croatia
Are you sure. I tried with a 3 phase 32A cable using a 32 socket charging to 3 phase 16A current and the mobile charger plus did not allow even though the cable is twice as thick.
