Comfort Access - login with second key New GTS
Novemberwhisky
Nicholas
BCN
GTS ST Crayon.
Hi this forum has been an essential source of info during my pre/post order process. Thank you all.
Picked up th new car this week, wow! - in all respects..
couple of questions -
using the second key as my wife’s - whenever she starts up the car it asks if she wants to login or continue as guest. Tried logging in with my porsche ID - the system then states that a user is already using that ID. Do i need to create a new My Porsche profile/account for her. she’s already been added as a second user on my account.
keyless access - I’ve ordered a trial of the comfort access And waiting for the OTA download. However, what is the correct operation of the door - press the dimple, touch the dimple, pull the handle? This is when the door handles are flush with key in pocket.
top tips for hands free boot/trunk access? We’ve had some laughs doing the Riverdance at the rear of the car but the arms are going to get tired holding the shopping bags.
thanks for any responses.
couple of photos of my pride and joy……
Porsche Taycan Comfort Access - login with second key New GTS 6866c985-00dd-42a4-ab1b-ffe4fa1637ff
Porsche Taycan Comfort Access - login with second key New GTS IMG_2710
Porsche Taycan Comfort Access - login with second key New GTS IMG_2711
Porsche Taycan Comfort Access - login with second key New GTS IMG_2713
1. Create a secondary Porsche ID for your wife. Use that id to login which will then be assigned to her key.
2. Ensure the comfort options are set how you want them - open all doors, foot gesture and so on. Handles will deploy on approach. If they have retracted but the car is not locked simply pull the handle. Touching the dimple will lock but should also deploy. I generally use the key fob to redeploy the handles or walk away and return.
Trunk - assuming option enabled and you have the key in your pocket the waggle will open or close the trunk. Stand in the middle swing your leg in and out once - don't stand too close.
Hood / bonnet - hand swipe from emblem down again with the key in your pocket.
