Eliminate next turn in right cluster circle?
2P168S
Atlanta, GA
2022 Taycan RWD
Anyone know a way to turn off the display of next turn in the right circle of the instrument cluster when navigating? I don’t need to see next turn info in 2-3 places and find it annoying to have to use the back button every single turn in order to see what I want to see in that right circle.
SergeyIndy
Sergey
Indianapolis
Reactions: Gru
Nigel
West Midlands, England,
Audi A4, Porsche Taycan GTS ST, Jeep Cherokee XJ.
Evening - I have the same (minor) issue, but in the right tube I cannot select navigation, it isn't there and also isn't available as a customisable line in the settings so I can't get to the next manoeuvre option. Any help appreciated - it's a small annoyance but I to end up pressing the return arrow to clear it off the display (2024 GTS ST)
SergeyIndy
Sergey
Indianapolis
Have you followed my instruction in the link. Specifically, you need to make sure that Navigation is in scope of the options to be selectable in the right tube. The way to manage scope is the following and I tested it just now and if it is not in scope, then it will not be shown in the right tube:
Settings > Displays > Instrument Cluster > Configure display scope
There you will see Navigation and it has to be checked to be in scope to be visible in the right tube.
