Experience with 22" inch wheels on Taycan?
Taycanturbolondon
London, UK
[QUOTE = "Arc, post: 39209, member: 2187"]
Heeft iemand hier 22 inch aftermarket-wielen?
Zo ja, hoe worden de rit, het rijgedrag en het bereik beïnvloed in vergelijking met 21 inch of 20 inch?
[/CITAAT]
No difference between 21" and 22" only the 22" look much better! The Vossen wheels are great!!!
I need those wheels in my life......
okkotonushi
Dirk
Germany
Porsche Taycan 4S+, Porsche Taycan CT Turbo S, Porsche 992 S, Genesis GV60 Sport
Saw your post about the grey axle and thought ....great. So i did it too and made them black.
Happy with that
Porsche Taycan Experience with 22" inch wheels on Taycan? 4c68a1a9-26e2-4635-827d-edcc39208b1a
Porsche Taycan Experience with 22" inch wheels on Taycan? 0a992505-c15b-4b83-aaeb-fe2f7d40129d
Persuader
2024 Taycan Turbo S Cross Turismo, 2024 Range Rover L461, 2020 Aston Martin DB11
Happy with that
What mm spacers do you have?
okkotonushi
Dirk
Germany
tibiafx1
AC
Atlanta, GA
Taycan 4S Chalk with Stealth wrap
[/CITAAT]
Looks awesome! Did you have the factory side skirts painted or did you have aftermarket skirts placed and painted? Very clean look!
BradMiller1102
Brad
Vancouver, WA
After trying to find an option that was in stock and hitting dead ends. I went with a 22x10 wheel for a Cayenne and had them custom painted later.
I had to go with the lowest profile tire I could find that would meet the weight load which oddly enough a Delante tire is the one that matched.
all together the new set only cost me $2,500 for everything after installed. Which is pretty crazy because the Rotiform FRA’s I wanted to order originally would have been$6,000 just for the wheels before tires and mounting.
so long story, they work, just need to make sure you have the tire size fit, and with any tires make sure they have the right load.
Porsche Taycan Experience with 22" inch wheels on Taycan? 4AD6B333-8C73-4E1E-BF33-44AC2E8C09A9
Porsche Taycan Experience with 22" inch wheels on Taycan? 788E987C-3BA5-4A8D-9F02-618613FF9D1F
Porsche Taycan Experience with 22" inch wheels on Taycan? 436258C5-4777-4B76-934A-646317DCC457
learsp03
Sean
Charlotte
2020 Taycan Turbo, 2023 GT3, 2024 Cayenne Turbo GT
[/CITAAT]
I’ve got the same wheels. Just installed them and having issues with the TPMS. Did you put original sensors back on? Any trick to getting them to “sync”?
EV Kris
kris
Telsa P85D - Taycan 4S
The dealer installed universal aftermarket TPMS sensors and configurated them with the car. Never had issues
Have you lowered your Taycan or is that stock hight?
EV Kris
kris
No ist stock hight. Friend of mine did installed some droplinks, lowered is by about 3cm. Looks good and sticks on the ground but bumps around @120km/h on the higway
