- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
Based on some cursory googling around it seems 2015 Mercedes was not limited by the US rules "headlight beam must operate as one" (meaning all-on or all-off, no partial-on allowed) because it had this feature implemented via an additional, physically separate spotlight, which was separate from low or high beams, similar to fog lights or side/turn lights. Current technology cars use matrix headlights for this, and that is what is disallowed by the NHTSA regulations. Couple of years ago the current administration made a big deal about allowing it, but in true government fashion after a victory lap by the president it's been stuck in government red tape since, here is an article @Jonathan S. found on the current state of this process:Seeing the other comments about highlighting a pedestrian leveraging the matrix headlights, my 2015 Mercedes S550 did exactly that. This feature was in a US/DOT car, not a European programmed version. When the nigh vision system identified a person or bicyclist or animal it would flash a box on them with the headlights and alert me on the dashboard by switching the entire screen to the nigh vision view and put a red box around the identified object. This happened once or twice a week in my regular drive (and the P-Car has never done this on the same drives with the same pedestrians and cyclists). So it appears that ability is not blocked in the US per say, it's just that some auto manufacturers have chosen not to implement this.
https://www.newsweek.com/nhtsa-roadblocking-headlight-technology-that-could-save-lives-1811354
This functionality is already implemented in Taycans equipped with Night Vision and Matrix Headlights, just disabled in North America due to NHTSA regulations. It works well outside of North America where it is allowed, the object which causes the warning is box flashed 3 times. Here is an example of what it looks like in action (in this example the car is changing lanes which makes the car think the pedestrian is in direct path of the car, hence the warning):
Sadly to get this enabled in the US, you have to reprogram/hack your own car, or pay someone to do it, then hope some recall, repair, or OTA update doesn't reprogram it back. Today in North America you only get a warning on your IC with the pedestrian highlighted in a yellow box (which also shows up when matrix headlights are highlighting the pedestrian).
