Finding charging station
carboard123
Connecticut
2021 Taycan 4s 1972 911T Targa
When I search for a charging station in the PCM nav section, pcm will show me all the charging stations in my immediate area (with selected filtering). Is there a way to input a city or town and have charging stations in the vicinity of that city or town show up in PCM? For example, if I want to find charging stations in a town 150 miles from my current location, can I input town name and have nearby charging stations show up in pcm so I can select such charging station as a destination and have battery preheat as I navigate to such station? Surely there must be a way to do this, but I can’t seem to find a way to do it directly from the pcm?
Just add as a destination and then add a stopover based on a local search for EVSEs or whatever.
Can do similar on the app and then send to the car.
FredC057
Fred
Brussels
Taycan Cross Turismo 4S (2022), Fiat 500Ce
In the pcm navigation type de destination and then hit the 3 dots … and search charging stations nearby and you can filter by power
SergeyIndy
Sergey
Indianapolis
I had the same issue when planning a trip. The way to do it, is to add your 150 mile away Location as a Favorite, it does not need to be a Destination. Then 3 dots from there will open a pop up to select Near By Charging Stations. I use a Filter to only show Stations with 150kW or above as otherwise you will get endless list of useless Stations.
