J1.2 Specific Question - Drive Modes
KapDad
Josh
New York, USA
BMW M850 / Taycan 4S CT In Production
Well, I'm pleased to say that I received my 2025 CT 4S! I think this was somewhere else in the forums but it was about the J1.1...
When i'm in Normal, is it possible to have it default to having the sport sound on, or do I have to enable it every time I change it?
Also, when in gravel mode, does the car stay raised the whole time or only under a certain speed?
Thanks!
prj
Estonia
www.mapev.net
Taycan CT 4 - 2026
Do you have Sport Chrono?
When you start the car it always defaults to the normal settings. If you have Sport Chrono you can configure the individual mode to what you want and then just switch to that.
It will lower itself above a certain speed for safety reasons.
KapDad
KapDad
Josh
New York, USA
I have sport chrono but no individual mode.
Mr.Smith
PaulS
Southern California
The car needs to always start in Normal mode due to the WLTP test cycle. Its not a programming matter for Porsche
You can program your Hot Key to give you the Sport Sound
jk981
2016 Cayman 2.7L
Does the sedan have a gravel mode equivalent, or is that only the CT?
anonymouse
Oxfordshire UK
Best approach for sport sound is to put it on the diamond button in the steering wheel, I have it set up there so I can flip on sound when I’m in an area with pedestrians or cyclists.
sveinaan
Svein
Norway
21 Taycan 4s
Individual only available on J1. 1. On J1. 2 you adjust those other modes
