- Jeremy
- Feb 9, 2021
- St. Louis, MO
- 2022 Macan S; 2021 Taycan 4S
I think @W1NGE ’s point was that the DC cover can be left in a state that will make it spring closed when the plug is removed. I just went out and looked and it looks like there’s about 3/16” clearance or more between a straight edge off of the bottom of where the plug goes in and the furthest the DC cover can move without locking. So, I think it’s possible. But any more and the DC cover will latch open.I get that you can get used to it. My point was simply that if I have to close the DC flap manually after each unplugging, I might as well close the main flap manually too (unlikely to close the DC flap but forget to close the port since the two are done together).
As I was looking at it, it occurred to me that they could easily make the plug depress the latch while inserted so that, even if it’s locked open for insertion, it springs close for removal.
The piece to unlatch is somewhat externally accessible (I can stick a small allen wrench in to trip it and close the cover). Seems like it might be an easy mod, but I’d have to look into it more.
