prj
- Jan 14, 2025
- Estonia
- Website
- www.mapev.net
- Taycan CT 4 - 2026
If the PCM gets bricked during update you can reset it via PIWIS.
In the extreme rare cases where it gets damaged, it is because the underlying hardware itself is damaged (probably issues with flash memory), so the PCM would have failed eventually anyway.
It's not because the update process does not work.
There have been quite many occurrences where PCM's (especially the early ones) have failed, and the failure just shows quicker during the update.
And while the TSB lists a lot of updates in a certain order, you really don't do that manually, PIWIS makes a work order and flashes everything afaik.
