My Porsche App - SOC at destination
smoothound
Alan
North West UK
CT Turbo Acid Green PTS
Folks - Short version....Please advise, how to set desired SOC at destination in the Phone MyP APP to allow me to send that to the car? Can it be done?
longer.....
In the Car's PCM - in the Charging plan - You can manually set a desired SOC % with which to arrive at your destination (for my next trip I need 30% on arrival). This setting helps the Nav charge planner to select a charging station close to/en-route to the destination to accomplish the desired SOC. Fine.
In the phone APP however, there does not appear to be an equivalent SOC setting (or have I missed it?) - and it just assumes that I want to arrive with 12% SOC (wrong).
So I guess that if I send the APP prepared route to the car - it would override my manually set value of 30% SOC at destination with the incorrect APP selected destination SOC of 12%.
Am I missing something? Is there anyway round this? Or do I just need to always use the nav in the car's PCM to plan routes, and ignore the App nav planner version as useless?
Cheers
longer.....
Cheers
I think you’ve answered your own question - you can’t do this.
The app is listing the SOC at the start of the journey and not the end. The default will be whatever the SOC was when the car last updated the app.
The destination SOC should still come into play (I don’t think it gets ignored) but the route you plan on the app will likely be recalculated based on the arrival SOC set in the PCM.
