New charging issue on 2022 Turbo ST.
Howieleem
Howard
Harpenden
Taycan turbo
Have had a new issue for about a week now.
With no timers set on the car, and just the General Profile set to 85%. The car will start to charge, then after a few minutes the charging is paused and there has appeared a new timer.
If i click on Direct Charging to overide the phantom timer, it charges for a few minutes and then a new timer appears which again halts the charging.
DC charging is limited from 350kw to 144kw also.
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
When the phantom timer kicks in, what color is the button by the charging port?
I believe it is blue if it's intentionally waiting.
Weird issue for sure.
SergeyIndy
Sergey
Indianapolis
Not enough information to help and not something I experienced or ever heard of on the forum.
We need to see your screen shots of all charging configs from the App, make sure it matches the car, I would recommend removing and reinstalling the app, basically trying to go back to the beginning making sure all is clear before setting up General Profile with 85% and trying it again.
Midlifecrisis
Worcestershire
Sounds like you have something like Octopus Go intelligent charging interfering. You haven’t registered your car with your electric company I the past have you?
