Phone holder?
Shawn_Turismo
Richmond, VA
Porsche Taycan Cross Turismo 4s
Shawn, the cable is wired purely via pressure fit in between the panels, here are some pictures that illustrate the routing.
Had one more question for you @nischalr, is this wireless charger holding your phone under hard acceleration etc? The magnet feels a bit less sticky compared to an Apple wireless charger.
nischalr
Ft. Lauderdale, FL USA
Taycan GTS ST, Macan 4S Electric, BMW i4
Shawn, I use an iPhone 15 pro without a case and it has never been an issue whatsoever even under hard acceleration and launch control. It is plenty strong despite being a little less so compared to the oem iPhone MagSafe charger. I can’t speak to how it would work with a case, depends on if the case has a good MagSafe magnet integrated or not.
Shawn_Turismo
Richmond, VA
That sounds good, I’ll do a bit of testing of my own, but that’s really helpful for now. Thank you again!
dirty martini
Rick
usa
Here is what I ended up doing. I can tuck the cable a little better.
Porsche Taycan Phone holder? 20240909_064529[1]
PorscheNewb
Carmel, IN
2022 Taycan GTS
I like the setup that I got from www.proclipusa.com
You choose a mount and then a phone holder specific to your phone and put it all together. I chose the Taycan mount obviously and a Charging magsafe mount, although there are many different options. The wire is run into the armrest console and plugged in to provide power. The wire is just pressure fit within the seams of the panels along the way and there was no disassembly.
Hey there, I am trying to find the same set up that you have and cannot see a right sided ProClip mount, just the left side. Also, cannot find the charging MagSafe mount that you have. Could you please point me to these two things?
Also, what type of charge speeds are you seeing with the MagSafe charger?
nischalr
This is the mounting base : https://www.proclipusa.com/products/855613-proclip-console-mount-porsche-taycan-2020-20xx
It is listed as left, but works on either side as it is symmetrical and you just flip it around the other way to use on the right. I confirmed that this was designed that way and not sure why they specify the left only. But this is the part number I ordered.
As for the charging mount, they have since discontinued the one I have and they have a newer version linked below. It seems to be a 15W charger, so pretty fast.
https://www.proclipusa.com/products/102814-magicmount-charge-elite-wireless-phone-holder-mount
PorscheNewb
Carmel, IN
2022 Taycan GTS
Perfect - thanks on clarification of both points for me!! I’m getting them, looks like the best solution out there.
George
Bristol, UK
Jaguar F-type V6S, Audi A6, Porsche Tycan
